RH-De Posted June 30, 2025 Report Posted June 30, 2025 Hi Team, i'm new with the software, and i have a Question about Measuring Tools in the Modelling... I cann't find any Ruler or something like that to measure distances or angles. Exist that option? cause' i made a restricted area (with known length) to measure distances but ist not Optimal. Thanks in Advanced Quote
hotline_oh Posted July 14, 2025 Report Posted July 14, 2025 Dear RH-De, Thank you for your inquiry. Unfortunately, PV*SOL is not a drawing programme comparable to AutoCAD or similar. A ruler is not available. If you have drawn a polygon (to extrude a building), you can move the corner points of the polygon. The length dimensions of the drawn polygon are displayed. After extruding the building, you can still adjust the building dimensions and enter the exact dimensions. Quote
