Electronio Posted May 27, 2025 Report Posted May 27, 2025 Hi, I'm running into an issue here and I hope someone had the same experience and can help me. I imported the HHD successfully but the Annual Consumption and Load Peak are way to high, which is not correct, as you can see in the pictures. Have anyone else had the same problem and if yes, have you found the solution? My guess is there's something wrong with the HHD but cant figure out what. would be grateful 1-1-24.csv Quote
hotline_oh Posted May 27, 2025 Report Posted May 27, 2025 Dear Electronio, Thank you for your inquiry. Have you checked whether you have selected the correct unit during import? If your values are not in kWh but in kW, you will get smaller results when importing: Quote
Electronio Posted May 27, 2025 Author Report Posted May 27, 2025 Hi hotline_oh, thank you for your response, unfortunately its not that.. I was testing it to see if the HHD are in kW but they're not. the HHD are in kWh. I uploaded the correct one. But still, even if you change it to kWh the peak is still sky high. Quote
hotline_oh Posted May 27, 2025 Report Posted May 27, 2025 Dear Electronio, Thank you for your feedback. What would be a realistic result? Quote
Electronio Posted May 27, 2025 Author Report Posted May 27, 2025 Hi Hotline, a realistic result would be 318721kWh with Load peak 36,4kW (assumption). I think the problem lies on the Data resolution time. Once I import the HHD it changes to 1min from 1h which obviously is incorrect. With Annual Consumption: With Imported HHD: Thanks Quote
hotline_oh Posted May 27, 2025 Report Posted May 27, 2025 Dear Electronio, Thank you for the clarification. There is incorrect data in your load profile that is responsible for the high peak load: Quote
Electronio Posted May 27, 2025 Author Report Posted May 27, 2025 That seems to be the problem! Thank you so much Quote
