hello everyone
is there a trick how a module can move freely?
e.g. rotate? no matter how i place the module it is never straight with the ridge.
many thanks in advance and best regards
Dear Lime,
Even if you're planning a roof-parallel system, don't select "Module Coverage." Instead, use the "Module Mounting" option and select a mounting system with a 0° tilt angle. For this mounting system, you can select the alignment to a reference edge.
