Lime Posted April 2, 2025 Report Posted April 2, 2025 hello everyone is there a trick how a module can move freely? e.g. rotate? no matter how i place the module it is never straight with the ridge. many thanks in advance and best regards Quote
hotline_oh Posted April 7, 2025 Report Posted April 7, 2025 Dear Lime, Thank you for your inquiry. Even if you're planning a roof-parallel system, don't select "Module Coverage." Instead, use the "Module Mounting" option and select a mounting system with a 0° tilt angle. For this mounting system, you can select the alignment to a reference edge. Quote
Lime Posted April 9, 2025 Author Report Posted April 9, 2025 hello hotline_oh thank you for the clarification—this is exactly what I was looking for. really appreciate your quick help. best regards Quote
