said allaw Posted March 23, 2025 Report Posted March 23, 2025 Hi, I’m working on a hybrid on-grid system with batteries and need help configuring the system to: Force zero export to the grid – I want to ensure that no excess energy is fed into the grid. Charge the battery only from PV and discharge only to the load – I need a way to prevent the battery from charging from the grid or discharging to it. Could you guide me on how to set this up in PV*SOL? Thanks in advance! Quote
hotline_oh Posted March 25, 2025 Report Posted March 25, 2025 Dear said allaw, Thank you for your inquiry. 1. You define a maximum feed-in power clipping at the feed-in point: 2. You define a charging strategy with C-charge (or I-charging) up to 100 %. The C-charge is taken exclusively from the PV system, never from the grid: By default, the battery only serves consumption and does not discharge into the grid. Quote
