JCS Posted February 7 Report Posted February 7 Trying to select a Pylontech Force H3 battery in the list, but Pylontech is not to be found in the list where batteries are selected. (sees that this battery is in the database) How do I solve it? Quote
hotline_oh Posted February 11 Report Posted February 11 Dear JCS, Thank you for your message. In PV*SOL, a battery system always consists of the charging/discharging unit (battery inverter or charge controller) and the batteries. The manufacturer Pylon Tech has inadvertently entered only the batteries but not the battery systems in our databases. We will contact the manufacturer and ask them to enter the battery systems. Thank you for your information. Quote
JCS Posted February 11 Author Report Posted February 11 Okay. Thanks for reply. We use Pylontech batteries together with Solis inverters. Can you (PVSol) create a "solution" to "connect them together" so that it can be calculated in PVSol, Or does it have to be done by Pylontech? Quote
hotline_oh Posted February 13 Report Posted February 13 Dear JCS, Thank you for your message. Battery systems with Solis inverters and Pylontech batteries are available in our database: Quote
JCS Posted February 13 Author Report Posted February 13 Hello, Thanks for reply. I have found the database (and tried to describe that I have it) What is the challenge is choosing Pylontech when I am in the calculations then it does not come up in the "list" of selectable batteries Quote
hotline_oh Posted February 13 Report Posted February 13 Dear JCS, Thank you for your message. In PV*SOL, a battery system always consists of the charging/discharging unit (battery inverter or charge controller) and the batteries. You first select the manufacturer Ginlong (Solis) and then the battery inverter with Pylontech batteries. Quote
JCS Posted February 13 Author Report Posted February 13 Thanks for reply. This is the procedure I was looking for. Thought one should choose battery not inverter. Brings up the list,but unfortunately the inverter to be used is not displayed (brings up the S6-EH3P 20K-H-ND but not the S6-EH3P 30K-H-ND Which should be used) Quote
hotline_oh Posted February 19 Report Posted February 19 Dear JCS, Thank you for your message. PV inverter: Please let us know which device is missing or send us the data sheet (hotline@valentin-software.com). We will then contact the manufacturer and ask for a database update. Battery inverter: We will contact the manufacturer and ask them to add the S6-EH3P30K-H-ND. Thank you for your information. Quote
JCS Posted February 24 Author Report Posted February 24 Hi Dear Admin, Thank you for answer. The batteri thas missing is: Pylontech S6-EH3P 30K-H-ND Solis datasheet_S6-EH3P(15-30)K-H-LV-ND_Global_V2.4_202408 1.pdf RESS-Installation Manual-Force H3 (V1.1) 5PMPA08-00250 EU_20240925122414A034 2.pdf Quote
JCS Posted February 25 Author Report Posted February 25 Hello. Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? (So it will be possible to calculate with these with battery) Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Hello. Dear admin. In the list of Solis hybrid inverters, I do not find: S6-EH3P15K-H-LV-ND S6-EH3P20K-H-LV-ND S6-EH3P25K-H-LV-ND S6-EH3P30K-H-LV-ND S6-EH3P8K-LV-ND-H S6-EH3P10K-LV-ND-H S6-EH3P12K-LV-ND-H S6-EH3P30K-H-ND S6-EH3P40K-H-ND S6-EH3P49K-H-ND S6-EH3P50K-H-ND Can you also add the hybrid inverters as well? Solis_datasheet_S6-EH3P(8-12)K-LV-ND-H_Global_V2,3_202407 3 (1).pdf Solis datasheet_S6-EH3P(15-30)K-H-LV-ND_Global_V2.4_202408 1 (1).pdf Solis_datasheet_S6-EH3P(30-50)K-H-ND_Global_V3,1_202410 (1).pdf Quote
hotline_oh Posted February 25 Report Posted February 25 Dear JCS, Thank you for your message. The missing devices will be added to our database. Quote
JCS Posted April 4 Author Report Posted April 4 Thank you for posting more Solis hybrid inverters. I have been looking for the following types (I have sent the datasheets for these as well): SOLIS S6-EH3P15K-H-LV 230V SOLIS S6-EH3P20K-H-LV 230V SOLIS S6-EH3P25K-H-LV 230V SOLIS S6-EH3P30K-H-LV 230V Do you have any opportunities to add these as well? Quote
