Gustavo Posted April 26, 2019 Report Posted April 26, 2019 Hello, I am new with the software. I have the load profile of 337 days in 15 minutes interval and I want to import these data into PV*Sol, so I can calculate the dimensioning of my pv system. The objective is 100% self-supply with the minimum injection. The pv system is grid connected. As I have the load profile, I chose "Grid connected PV System with Electrical Appliances". I tried to add the data in "Consumption-->New Appliance-->Impoart and load Load Profile-->Import new load profile" but it only accepts .txt files, so I copied my data array in excel but I receive the prompt "Number of data records is wrong". How can I work with the load profile data that I have collect over the last past year? Please help. Thanks Gustavo Quote
developer_mh Posted April 26, 2019 Report Posted April 26, 2019 Hi Gustavo, you would need to fill up the data series for 365 days. If you have a 15 min resolution, you need 35040 values for one year. Since you have only 337 days of measurement, PV*SOL 'complains' that the number of records is wrong. The solution is to provide a full year of data, then it works. Kind regards, Martin Quote
RobertK Posted January 8, 2020 Report Posted January 8, 2020 Hi, I have a problem with load profile data import - 15 min, 365 days, kW. it is 35040 values and program says: "No read permission of the file ...." I have tried on csv, txt and prn files Kind Regards Robert Quote
developer_mh Posted January 8, 2020 Report Posted January 8, 2020 Hi Robert, the error message indicates that the file is locked by your file system. The reason might be that it is opened in another application, or that it is located on a network drive where PV*SOL doesn't have access. Try to copy your values in a txt file and place it on your desktop. Close all programs that possibly have a finger on this file (including other instances of PV*SOL), and then try to import again. Kind regards, Martin 1 Quote
Leon Norris Posted January 10, 2020 Report Posted January 10, 2020 Could it be "run as administrator" issue? Quote
developer_mh Posted January 10, 2020 Report Posted January 10, 2020 I hope not, since PV*SOL doesn't require administrator rights. Quote
Matas Posted August 6, 2025 Report Posted August 6, 2025 Hello, I have an issue that is related to load profiles. Number of data records is wrong. Expected: 8784 Number in file: 8784. 60 minute time intervals, 366 days, kWh I tried .csv as well as .txt I checked there are commas only dots as well. Closed all the tabs where that file was open. What could be the issue? Thanks in advance, Matas Quote
developer_mh Posted August 11, 2025 Report Posted August 11, 2025 HI Matas, could you send the file along with your question to hotline@valentin-software.com, please? Thank you, best regards, Martin Quote
