Petr Posted November 14, 2024 Report Posted November 14, 2024 Hello, i made Trina TSM-NEG18R.28 module to PVsol, I looks fine, but when I rotate to horizontal, the cells stay square and do not fill module area: What to do? Quote
hotline_oh Posted November 14, 2024 Report Posted November 14, 2024 Dear Petr, Thank you for your inquiry. Please send the corresponding project file (*.pvprj) to hotline@valentin-software.com, so that we can take a closer look at it. Quote
Petr Posted November 14, 2024 Author Report Posted November 14, 2024 Hello, original project was to big (260MB), I sent test project to your email. Now I also tried to make brand new module just set cells to 108 and use size 1134x1961 and it results to same problem. Will it be issue to set different cell cout? How cell count affect simlation results? Thank you. Quote
Petr Posted November 14, 2024 Author Report Posted November 14, 2024 Everything start to work ok, If I just change module to cell count of 140 Quote
hotline_oh Posted November 18, 2024 Report Posted November 18, 2024 Dear Petr, As mentioned via email: The problem is the frame width. If you set the frame width to 30mm, the texture is displayed correctly. Quote
