Dear Karina Suharevska,
Thank you for your inquiries.
1 hour ago, Karina Suharevska said:
OUh, it looks like it does not work in my country - Latvia.
Unfortunately, there is no Google Solar API coverage for Latvia.
EXTRA question - how can I set a ground level and slope if I want to load data file - picture.
You have two options:
Either you start the 3D planning with a tilted open area and then insert your map section as a texture. (You set the scale of the map section via the size of the open area).
Or you can import the map section (at the correct scale), then drag one (or more) monopitch roofs onto the map section and cover the monopitch roofs. (This has the advantage that you can map different slopes).
