ROBERTO VANIN Posted October 25, 2024 Report Posted October 25, 2024 Good morning I should enter the technical specifications of a new photovoltaic module into the database. How should I do this? Kind regards Roberto Vanin Quote
hotline_oh Posted October 28, 2024 Report Posted October 28, 2024 Dear Roberto Vanin, The database is maintained by the manufacturers themselves. The manufacturers have access to an online database in which they enter their products. We then carry out database updates at regular intervals and the new entries are transferred to the users' databases. Please send us the data sheet to hotline@valentin-software.com, we will then contact the manufacturer and request an entry in our database. However, you also have the option of adding modules yourself. The easiest way is to copy an existing data record and overwrite the values using the data sheet. As there is no information on low-light performance on the data sheet, you must select ‘Standard’. You can also import pan files, if available. Quote
