Victoria Ellis Posted October 21, 2024 Report Posted October 21, 2024 I have come in to an issue with the MPP trackers for the Ginlong (Solis) inverters example i have used 100kW 5G inverter the inverter has 16 MPP ports on it but the software on states 10 this is causing issues for my team. the S5-GC60kW has 12 MPP's and the software only states 6 again causing issues for my team and the set up. how can i edit these so i can configure correctly? Quote
hotline_oh Posted October 21, 2024 Report Posted October 21, 2024 Dear Victoria, Thank you for your inquiry. According to the datasheets, the number of MPP trackers for Solis-(100-110)K-5G and S5-GC(50-60)K correspond to the data in our database. Quote
Victoria Ellis Posted October 21, 2024 Author Report Posted October 21, 2024 The images attached are of the MPP's for each inverter. Quote
hotline_oh Posted October 21, 2024 Report Posted October 21, 2024 Dear Victoria, For both inverters, the max. input strings number is twice as large as the number of MPP trackers. Two strings can be connected to each MPP tracker. Quote
