Oliveira Posted October 21, 2024 Report Posted October 21, 2024 Hello, I hope you are well. My question is, I wanted to expand an existing solar system, at the moment there are 8 480Wp modules with a 6 Kw inverter with only one string used. I now wanted to expand the system with newer 580Wp modules up to the maximum of this inverter. But I don't understand how I do this in the software, inserting 2 different modules for the same inverter. Thank you Quote
hotline_oh Posted October 21, 2024 Report Posted October 21, 2024 Dear Oliveira, Thank you for your inquiry. Create a second module area for the second module type. In the inverter configuration window, select ‘Configure module areas together’ and select your inverter. You can find more information in our help section. 1 Quote
Oliveira Posted October 21, 2024 Author Report Posted October 21, 2024 Thank you very much, I managed to do it! Quote
