Rahil Pednekar Posted September 30, 2024 Report Posted September 30, 2024 Rahil Pednekar <rahilpednekar97@gmail.com> 13:16 (14 minutes ago) to Hotline I have a CSV file from PVsol downloaded (in cc) and I have a couple questions regarding it. It is interesting for me to find out which column should be used to determine the AC generation profile of the system? The energy that is available to use for grid-feed in or to supply the tenants. Also, is it the case that these columns are always structured the same way? If I want to simulate a system which contains battery, thermal system, etc, even then we can expect the columns to be named in the same way? Looking forward to hearing soon. pv_data.csv Quote
hotline_oh Posted October 1, 2024 Report Posted October 1, 2024 Dear Rahil Pednekar, Thank you for your inquiry. The column that describes the power that is (AC) effectively available either for grid feed-in or to supply the building/tenants is the column DH fed-in energy (Eingespeiste Energie). The column headings correspond to the simulation results and they are always the same, but appear in different columns depending on the project (type of system, number of module surfaces, inverters used, etc.) Quote
