Miro Posted September 27, 2024 Report Posted September 27, 2024 Hello support, I have instaled a new version 2024 R8 and tried to string some project. Here is a output how does PVSOL create a string plan: Here is a exported plan which is faulty: I set meander before as usually: It doesnť work properly as you can see. Please correct it. I send also pvsol project for check: TGS vedlejší budova.pvprj Thank you. Miroslav Quote
hotline_oh Posted September 30, 2024 Report Posted September 30, 2024 Dear Miroslav, Thank you for your inquiry. The course of the strand depends on the configuration. If you have already created a cable plan and subsequently make changes to the wiring, the cable/string diagram is not always updated. You must then delete the cable plan, switch back to the Module wiring page and then back to the Cable plan page. Everything is then updated and the cables run in a meandering pattern, see attached file. TGS vedlejší budova VAL.pvprj Quote
