September 19, 20242 yr comment_17466 Hello. I am having problems because I want to simulate a grid-connected installation with batteries and I want to use a hybrid inverter. Once selected, it sends me directly to select the battery inverter and the batteries and I do not need a battery inverter because I am using a three-phase hybrid inverter to which the battery can be coupled. I need to know how to tell the software that it is a hybrid inverter. Can someone advise me? Thanks. Report
September 20, 20242 yr comment_17483 Hi Hircel, hybrid inverters are actually handled as two devices in PV*SOL, even if in reality this is only one device that you mount onto the wall. So you would choose the hybrid inverter as PV inverter (as you already did, I assume), and then you choose the same model as battery system. Kind regards, Martin Report
