Michal Vondrka Posted September 11, 2024 Report Posted September 11, 2024 Dobrý den, narazil jsem na problém v projektování instalace. Jakmile jsem se dostal na počet panelů v instalaci na 7500 kusů, tak mi to nechce dovolit přidávat již žádné další panely. Potřebuji naprojektovat instalaci s cca 11.000 panely. Quote
hotline_oh Posted September 11, 2024 Report Posted September 11, 2024 Dear Michal Vondrka, 3D planning is limited to 10,000 modules for roof-parallel systems and 7,500 modules for ground-mounted systems. These values cannot be exceeded. You could try to plan the system in 2D. Here you are able to define an arbitrary number of module areas with 100.000 modules each. Or you could try to plan the system in two separate sub-systems. Quote
