Alin Furcea Posted September 2 Report Posted September 2 Hello, I'm a registered user of PVSOL PREMIUM and I need to do at least 20 projects where the full system contains the following: PV system EV charging stations Storage systems Heat Pumps The above are connected to the electrical grid and controlled, in a production unit or small hotel facility. I see that in PVSOL Premium there is only this: https://ibb.co/cJZk3Xx To do the simulations and have a complete electrical consumption, I also need the heat pump to be integrated into the full analysis to have the behavior. Can you pls help me with a solution? Quote
developer_mh Posted September 10 Report Posted September 10 Hi Alin Furcea, the system type that you would require is not available (yet) in PV*SOL. It is very high on our priority list, but I can't give a date of release yet. In the meantime you can add the heat pump as electrical appliance, then you can simulate all in one system as required. Just with the disadvantage that the heat pump is treated like a normal consumer and hence not controllable. Best regards, Martin Quote
