Kaspars Posted August 14 Report Share Posted August 14 Hi all, I am now testing PVSol with battery storage and I see that I do not get consistent/correct results when adding battery storage using DC intermediate coupling and AC coupling. DC intermediate circuit coupling I am setting Maximum Feed-in Power clipping in the settings but I can see, when exporting simulation excel file and in the report that it is exceeded (Value under Grid Export in Excel). The simulation PDF skips multiple charts and tables which are presented when AC coupled system is used: "Battery Charge" data missing "Clipping at Feed-in Point" missing "Battery charge (PV system)" missing "Battery charge (Grid)" missing The issue with the Maximum Feed-in Power clipping is the most important as it creates erroneous data/output. I would like to understand if behaviors 1 and 2 are well known issues or am I doing something wrong in the configuration. Quote Link to comment Share on other sites More sharing options...
developer_mh Posted September 10 Report Share Posted September 10 Hi Kaspars, could you send a project or some screenshots in order to clarify the issue? I just checked it again, and for me it works fine. Kind regards, Martin Quote Link to comment Share on other sites More sharing options...
