aapn77 Posted March 28, 2019 Report Posted March 28, 2019 As a double check I run my own Excel calculation and when comparing that to the PV Sol calculation I find a difference which I hope you can explain. Please look at the attached file; Financial Analysis; First year saving. SEK 5.233,68 Then look at the cash flow Table year 1; Electricity saving. SEK 5.131,06 Should´t these two figures be the same? I have 0 in all inflation rates to eliminate that as an explanation. Next Total Payment from Utility in First year is SEK 6.037,03 I would expect that to be equivalent to Feed-in / Export Tariff in the Cashflow table or ? Regards, Quote
developer_mm Posted March 29, 2019 Report Posted March 29, 2019 Hello aapn, in generell you are right, these values are equivalent: Total Payment from Utility in First Year = Feed-in / Export Tariff First year savings = Electricity Savings  But the parameters from the cashflow table take also the parameter "annual average return on capital employed" from the financial parameters into account.  Kind regards, Marcel Quote
