Gorka Posted May 28, 2024 Report Posted May 28, 2024 CUAL ES EL MEJOR MODELO DE IRRADIACIÓN DIFUSA PARA UTILIZAR EN PROYECTOS EN ESPAÑA? QUIERO QUE LA GENERACIÓN QUE CALCULA EL PVSOL SEA LA MAS CERCANA A LA QUE CALCULA EL PVGIS. Quote
developer_fw Posted May 29, 2024 Report Posted May 29, 2024 Hello Gorka Quote WHAT IS THE BEST DIFFUSE IRRADIANCE MODEL TO USE FOR PROJECTS IN SPAIN? I WANT THE GENERATION CALCULATED BY PVSOL TO BE THE CLOSEST TO THE ONE CALCULATED BY PVGIS. To get the highest similarity you should use the same or most similar model. PVGIS seems to use the model by Muneer, T., Solar radiation model for Europe. Building Services Engineering Research and Technology 1990, 11(4), 153-163. (https://joint-research-centre.ec.europa.eu/photovoltaic-geographical-information-system-pvgis/getting-started-pvgis/pvgis-data-sources-calculation-methods_en#ref-3-calculation-of-solar-radiation-on-inclined-planes). This model is not available in PV*SOL. And for the first part of your question you might need recordings of diffuse and direct irradiation for being able to compare it to the model. Kind regards Frederik Quote
