I wouldn´t want to speak about specific brands, but as stand alone systems are getting more and more common, and one of the most specialized company in this area is Victron it would be great if you can introduce in your data base their products. I don't know how that it works, between you and the solar brands, but at least you could create some PVSOLs items that you can use in a wide range of situations. And also add some connection schemes so you can use a charger/inverter for instance.
Thanks for your attention
Hi Jon,
thank you for your input. Yes, we are aware of the fact that our list of offgrid battery inverters is limited to SMA products at the moment. And we definitely want to change that. I can't tell you a schedule yet but we are working on the extension of our databases, and the offgrid systems will be one aspect that we want to ameliorare.
For the moment you could copy a SMA component and change the company, name and eletrical properties to your likings.
