Jakubson Posted April 26, 2024 Report Posted April 26, 2024 Hi, I have problem with extracting 3D models. When I want to extract 3D models of building with more points, there is a bug. I can extract only trees. When I choose building it comes to error. There was no problem in previous versions. Quote
developer_fw Posted April 30, 2024 Report Posted April 30, 2024 Hello Jakubson On 4/26/2024 at 9:48 AM, Jakubson said: I can extract only trees. When I choose building it comes to error. There was no problem in previous versions. Thank you for reporting! I forwarded this issue as a ticket to the responsible developer. This is fixed within the upcoming release. Meanwhile you could work with a simpler building and add barred areas to resemble the rounded corner. Alternatively you could create a model of the building externally and import it as .obj file into PV*SOL. Kind regards Frederik 1 Quote
