Anas Posted April 25, 2024 Report Posted April 25, 2024 Hello PV*SOL team and community, I've been planning projects with the software since a while now and I'm looking forward for what's coming. lately I have faced an issue and I coudln't seem to find the solution. I used to export the string planes as a dxf. format and continue the work in AutoCad and all was good till now where I get other units in autoCad as shown in the attached screenshot, this issue only happens when I export the string planes, and units stays correct when I export the planes before the connection 'only in pv modules placement'. I tried resetting PV*SOL and AutoCad to the factory settings and the issue is still there. looking forward for your help. Quote
developer_fw Posted April 30, 2024 Report Posted April 30, 2024 Hi Anas On 4/25/2024 at 11:57 AM, Anas said: and all was good till now Could you elaborate from which version on this issue surfaced? On 4/25/2024 at 11:57 AM, Anas said: and units stays correct when I export the planes before the connection 'only in pv modules placement' This is a good trail, thanks. Might you be so kind and send your .pvprj file via private message here in the forum so we can have a look into it? Thank you in advance and kind regards Frederik Quote
developer_fw Posted May 7, 2024 Report Posted May 7, 2024 Hello Anas On 4/30/2024 at 3:51 PM, developer_fw said: Might you be so kind and send your .pvprj file via private message here in the forum so we can have a look into it? Thank you for your project file. There was a scaling bug when exporting string plans, unfortunately. It will be fixed in version 2024R7. Kind regards Frederik Quote
Anas Posted May 7, 2024 Author Report Posted May 7, 2024 6 hours ago, developer_fw said: Hello Anas Thank you for your project file. There was a scaling bug when exporting string plans, unfortunately. It will be fixed in version 2024R7. Kind regards Frederik Thank you Frederik, when could we expect the next update? Quote
developer_fw Posted May 7, 2024 Report Posted May 7, 2024 Hi Anas, the upcoming release is planned for the first half of June. This is not a promise Kind regards Frederik Quote
