Keith Posted March 5 Report Posted March 5 Hi, Â Is it possible to export inverter data as a OND file? Â K Quote
developer_fw Posted March 6 Report Posted March 6 Hello Keith, 19 hours ago, Keith said: Is it possible to export inverter data as a OND file? The .OND file format is used internally within PVSyst (https://www.pvsyst.com/). There is no publicly available specification of the format and the .OND file format must not contain all relevant data from a datasheet. This is why there is no export available. Kind regards Frederik Quote
Thura Posted September 3 Report Posted September 3 On 3/6/2024 at 4:22 PM, developer_fw said: Hello Keith, The .OND file format is used internally within PVSyst (https://www.pvsyst.com/). There is no publicly available specification of the format and the .OND file format must not contain all relevant data from a datasheet. This is why there is no export available. Kind regards Frederik Why do PV*SOL accept OND file? What are the difference between the parameters in OND file and the PV*SOL input capabilities to input data? May you explain details pro and cons between them? Quote
developer_bh Posted September 10 Report Posted September 10 Hello Thura, We accept them as a service for our users who use these files. The OND file can contain all the data PV*SOL needs to add a valid inverter to our database. But as my colleague said, there are no real specifications, the file can have different structures and input data. Some may only contain a fraction of the data we need. That's why there is a check before the import, where you can add the missing data manually. Kind regards, Ben  Quote
