Abdel Rahman Posted January 24, 2024 Report Posted January 24, 2024 Hi PVsol team I hope to get your help. I have solar PV system on flat roof. I am facing a problem with the title angle and the pitch (Row distance). I tried to change the pitch and the tilt angle values but PVsol didn't change anything so always the tilt angle is 30 degrees and the row distance 1.982m. So I tried to increase the row distance value by increasing the value of "Row depth" but nothing has been changed in PVsol. How can I change the row distance "the pitch" and the tilt angle in PVsol? Quote
developer_fw Posted January 25, 2024 Report Posted January 25, 2024 Hello Abdel Rahman 16 hours ago, Abdel Rahman said: How can I change the row distance "the pitch" and the tilt angle in PVsol? I assume you do mean changing the properties of existing mounted module systems, which are already placed onto module surfaces. I'm afraid that is not possible. You could change the properties of a mounting system and replace the modules. Kind regards Frederik Quote
