Go green BG Posted January 3, 2024 Report Posted January 3, 2024 I am preparing a project where the construction of the panels can change its slope. This happens mechanically two or three times a year. How can I give an annual production forecast when the slope is 15 degrees in one part of the year and 45 in the other? Thanks in advance! Quote
developer_fw Posted January 3, 2024 Report Posted January 3, 2024 Hi Go green BG At the moment you have to do several simulations and could zip together the exported simulation results afterwards. But thank you for the input, this is a nice idea which I added to our list of feature requests. Kind regards Frederik Quote
Go green BG Posted January 3, 2024 Author Report Posted January 3, 2024 Do I collect the projects outside of the pv sol program or is there a way to make it happen within it? Quote
developer_fw Posted January 4, 2024 Report Posted January 4, 2024 Hello Go green BG 20 hours ago, Go green BG said: Do I collect the projects outside of the pv sol program or is there a way to make it happen within it? I am not sure I understand your question correctly. In this case it seems best to have several projects with adapted inclinations. There is no way of combining several projects into one .pvprj file, I'm afraid. Kind regards Frederik Quote
