Martijn Posted December 11, 2023 Report Posted December 11, 2023 When i search with keyword 'BYD' in the selection list of battery's. there comes no option. when i search for 'gen24' from Fronius. then the HVM box of BYD is there. why not on keyword BYD? that would it be easier to find and to work with PVsol. but after goog looking. i sees it is the whole system of battery and inverter together what you can select, thats probably why BYD is notĀ findable. its only an battery. Then you can better put above the search window 'INVERTER MANUFACTURER' Quote
developer_fw Posted December 12, 2023 Report Posted December 12, 2023 Hi Martijn Thank you for your request. The fields of the fast selection are separated and do not allow a comprehensive search. In this case Fronius is the manufacturer which can be found in the Manufacturer dropdown. For a comprehensive lookup try opening the database via the Detailed Selection: After selecting All Companies you could filter for byd... 20 hours ago, Martijn said: Then you can better put above the search window 'INVERTER MANUFACTURER' It is the dropdown for the manufacturer who sells the system despite the battery its using but I acknowledge it could be misleading. Kind regards Frederik 1 Quote
