Sam N Posted December 1, 2023 Report Posted December 1, 2023 Hi, I have designed one building from two buildings due to its geometry. This means that what should be one roof face is actually two. I have very few modules on the second roof face and want them to be incorporated into the strings with the modules on the first roof face. When I am in the inverter configuration however each string has a dropdown menu for which roof face it should be on. Thus not allowing modules on different roof faces to be on the same string. Is there a way around this? In my situation this time I imagine I could remove some panels from one face and move them to the other, but not sure what to do if this couldn't be done. Cheers Quote
developer_fw Posted December 4, 2023 Report Posted December 4, 2023 Hello Sam N On 12/1/2023 at 2:53 PM, Sam N said: Is there a way around this? What you are looking for is the Polystring Configuration. The following thread is answering a similar request, so I do want to point you to it first: Does this help resolving your question? If not, feel free to ask! Kind regards Frederik Quote
