Hello Fatih DİLMAÇ
29 minutes ago, Fatih DİLMAÇ said:
How can I fix it or can it be fixed?
Could you elaborate what you are trying to achieve? Did you try to move an object within the 3D environment? Could you provide a screenshot of the error window?
Kind regards
2 minutes ago, developer_fw said:
Hello Fatih DİLMAÇ
Kind regards
Hi, I want to change the distance between modules vertical and horizontal one by one to 2cm but when I change vertical or horizontal distance and click the other one I get the "this value causes a collision or pvsol... "
Hello Fatih DİLMAÇ,
if there is an object or an restriction area next to the modules that would collide with a module after increasing the module spacing, this error occurs. It also occurs when the increasing of the module spacing would lead to an overhang over the roof surface. If both these cases do not apply, could you please send your project file to me via private message in this forum.
Kind regards
Mikio
