Hi,
we are interested in using photogrammetric mesh models created using Agisoft Metashape in PV Solar. However, the maximum dimensions of our model seem to be completely out of range (see image_1.jpg). Once located, the dimensions look fine (see image_2.jpg). Unfortunately, we still can't change anything like rotation angle as it always produces an error message (see image_3.jpg).
Therefore, what export options do you suggest for Metashape, particularly regarding coordinate reference system?
Thanks a lot in advance!
Hello DronesToSolar
I must admit I do not have any experience with Metashape, so I could not give any advice for the export.
You could provide a custom scale when importing and adapt the ratio until you do get the real height of your object:
I hope this helps. Nice model by the way!
Kind regards
Hi Frederik,
thanks a lot for your very quick reply!
Actually, I just found the reason for the settings being somewhat odd. The Windows settings regarding decimal point (instead of comma) resulted in a conflict with the PV Sol settings. Once I changed the Windows settings to a decimal comma, everything looked fine.
Best regards
  • Like 1
