Hello. I have 4x Solax X3-Hybrid-15kW and i want to connect 4xT58 batteries on each inverter ( 16xT58 in total). In baterries system I can only choose one inverter to connect. Is there any solution to connect batteries to each inverter ?
Thank you.
HI Jakubson,
this is a feature that will come in the next major version, PV*SOL premium 2024 R1.
Right now, with 2023 R7, the only possibility is to define a inverter configuration with 4 times the Solax X3-Hybrid-15kW, and then connect the batteries to them and set the amount to 4 as well. But this only works if you have a 2D project or a 3D project without shadows.
  • Like 1
