Boo Posted October 15, 2018 Report Posted October 15, 2018 Dear PV*SOL community, I would like to ask where can I change the "Maximum permitted current" value? I have tried searching in the inverter that I've created as well as the configuration limits setting but still couldn't find the "Maximum permitted current" setting. Hope to hear from you soon. Thank you. Boo Quote
developer_mm Posted October 16, 2018 Report Posted October 16, 2018 Hi Boo, It seems that you have forgotten to configure the mpp-tracker of your inverter (values on the picture). Because your inverter has a maximum power of 2775 kW and your (only) mpp-Tracker only 33.2 kW, this does not fit..... The "maximum input power for the mpp" and the "maximum permitted current" are calculated with values from the mpp-tracker and the configuration limits (tolerances). Kind regards, Marcel Quote
