Tecnico Clire Posted August 25, 2023 Report Share Posted August 25, 2023 Is it possible to use different FV modules on a single 2D project? I need it for a plant revamping project/simulation. Kind Regards Quote Link to comment Share on other sites More sharing options...
developer_fw Posted August 25, 2023 Report Share Posted August 25, 2023 Hello Tecnico Clire 1 hour ago, Tecnico Clire said: Is it possible to use different FV modules on a single 2D project? Definitely! You have to create a new module area containing the new modules on the page PV modules. On the page Inverters you have to take the following steps: Configure module areas together Activate Polystring Configuration Connect strings with the same number in series (I assumed this is what you did ask for) Configure the correct number of modules of the module areas Kind regards Frederik Quote Link to comment Share on other sites More sharing options...
Tecnico Clire Posted August 25, 2023 Author Report Share Posted August 25, 2023 THANKS! that's what i need! Quote Link to comment Share on other sites More sharing options...
