Eslam Adel Posted October 12, 2018 Report Posted October 12, 2018 Hello, Why all ReneSola PV modules are out of date in the database? Thanks! Quote
developer_mm Posted October 15, 2018 Report Posted October 15, 2018 Hello Eslam Adel, this is odd. I can see ReneSola PV modules that are available. What version of pvsol are you using? Kind regards, Marcel Quote
Eslam Adel Posted October 15, 2018 Author Report Posted October 15, 2018 Hello Marcel, I am using the last version, and I see the same as the attached photo, but I am using ReneSola modules poly 280 Wp which is not existing along with all the modules in attached datasheets. Kindly have a look! Thanks for your support! Regards, Eslam 295-310W 5BB MONO PERC 3535 EN.pdf 355-370W 5BB MONO PERC 4035 EN.pdf Virtus II(5BB)265W-285W 3535 EN.pdf Virtus II(5BB)315W-335W 4035 3.2mm EN.pdf Quote
developer_mm Posted October 16, 2018 Report Posted October 16, 2018 Hello Eslam Adel, yes, in fact, these PV modules seem to be missing. In general, our colleagues at database@valentin-software.com are always a good contact person. However, I will inform them about these missing modules. To be able to use these modules now, you can add the missing ones yourself. If you don't know how to do this, just have a look here: It was a similar problem, but only with inverters. You can adapt the same steps for PV modules. Kind regards Marcel Quote
Eslam Adel Posted October 21, 2018 Author Report Posted October 21, 2018 Dear Marcel, Thanks for your reply. Ok I will contact them to add them ASAP. Regards, Eslam Quote
