August 9, 20233 yr comment_14050 Hi, Solis inverter 110k 5G pro has 10mppt and 20 input on the datasheet but on PV sol database for same it shows 8 mppt and 16 inputs , could you please check this ? Report
August 9, 20233 yr comment_14052 Hi Rakeshevergen There are several variants of this product within the database. It seems that the [MAX|PRO] versions do have a smaller number of trackers and inlets: I double-checked the datasheet (https://www.ginlong.com/uploads/file/Solis_datasheet_Solis-(80-110)K-5G-PRO_Global_V2,7_2023_06.pdf): Everything correct. Kind regards Frederik Report
