RaW Posted August 8, 2023 Report Posted August 8, 2023 Hi, I have attached a redacted financial summary from a PVSol report. Could you possibly explain how we have reached the figure of £151,871.73 'electricity savings' for the first year please (last page)? Thank you. financials.pdf Quote
developer_fw Posted August 10, 2023 Report Posted August 10, 2023 Hello RaW might you be so kind and send me the .pvprj file via private message here in the forum? It is necessary to check possible parameters set on the page Financial Analysis. Thank you in advance and kind regards Frederik Quote
RaW Posted August 10, 2023 Author Report Posted August 10, 2023 Hi Frederik, Happy to keep this in the forum so it might help others understand if that's ok.. Here are the images you are looking for: Quote
developer_fw Posted August 16, 2023 Report Posted August 16, 2023 Hello RaW On 8/10/2023 at 2:22 PM, RaW said: Happy to keep this in the forum so it might help others understand if that's ok. I am perfectly alright with that. On 8/10/2023 at 8:30 AM, developer_fw said: might you be so kind and send me the .pvprj file via private message here in the forum? It is way easier being able to copy values from the project, that is why I am asking for the .pvprj file, but thank you for the screenshots. Kind regards Frederik Quote
RaW Posted August 17, 2023 Author Report Posted August 17, 2023 Thank you, let me know if you need any other info. Quote
developer_fw Posted August 22, 2023 Report Posted August 22, 2023 Hi RaW I did not receive any private messages so far. Kind regards Frederik Quote
RaW Posted August 22, 2023 Author Report Posted August 22, 2023 Frederik, I didn't send it, sorry, I misunderstood. Although a little more difficult for you, are you not happy to use my screenshots? All the information you need is there and there are only a couple of figures you need to get from them. The rest of the figures are easily copied/pasted from the pdf I attached in my first post. If you could use the screenshots I'm sure it would be easier for everybody else to understand too as everything shown will be relevant to them. If you simply aren't happy in doing so, just let me know. Thank you. Quote
developer_fw Posted August 25, 2023 Report Posted August 25, 2023 Hi RaW It is easier for us to have the .pvprj file since looking up things within the project is familiar, there is no inconsistencies that might happen between screenshots and project files (which did happen before in different threads leading to not being able pinpointing the problem). So please, could you just send the project file via private message? I could send a screenshot and description here. Kind regards Frederik Quote
Pradyuman Posted January 31, 2024 Report Posted January 31, 2024 Hi Frederik, Can you please write here what was the solution for the problem? I am facing similar problem. Thanks, Raj Quote
developer_fw Posted February 1, 2024 Report Posted February 1, 2024 Hello Pradyuman 17 hours ago, Pradyuman said: Can you please write here what was the solution for the problem? I did not receive any files so I did not investigate the request. Kind regards Frederik Quote
