Mohamed255 Posted August 5, 2023 Report Posted August 5, 2023 I configure a system with (plenticore plus 8.5 (battery option) inverter) and when i could not find this inverter in battery inverter list as attached. so how could i select the hybird inverter to feed the battery. Quote
developer_fw Posted August 7, 2023 Report Posted August 7, 2023 Hello Mohamed255 Hard to tell without the .pvprj file which you could send to me via private message here in the forum. I do not have any problems configuring a system according to your description: Kind regards Frederik Quote
Mohamed255 Posted August 7, 2023 Author Report Posted August 7, 2023 The file is attached. My issue is in selection/configuration of battery inverter. your attached screen is different from the screen which appear to me. could you told me which version is the one you used. Quote
developer_fw Posted August 8, 2023 Report Posted August 8, 2023 Hello Mohamed255 Thank you for sending the project file. Are you sure that you want to use the selected system type Offgrid? Since your project is located within a small town I guess the building is already connected to the electricity grid. You could change it on the page System Type, Climate and Grid: This is the reason for the differing view on the page Battery System. Kind regards Frederik Quote
