Hello everyone,
I have problems while importing objects from Sketchup, everytime have some shading crashes, it's 100% sahde for most of panels . How can I fix it?
Hello Samir
This could be an issue with the 3D object itself, but its just a guess.
Could you send me your .pvprj file and the 3D object file which you did use for the import via private message here in the forum?
Thank you in advance and kind regards
Hi Samir
Thank you for sending the project files.
What do you mean by 100% shade for most panels? I did the direct radiation shading analysis and get the following percentage values:
I could not simulate the project since there was no inverter configuration within your project, I'm afraid. But my guess is that shading losses must not be too high.
Kind regards
