Rakeshevergen Posted June 27, 2023 Report Posted June 27, 2023 Hi i'm trying to configure soils 110k 5g pro inverter but only solis 5g 110k inverter is working. what is the issue for pro version to work ? it says all module not configured please find the attached Quote
developer_fw Posted June 28, 2023 Report Posted June 28, 2023 Hello Rakeshevergen 15 hours ago, Rakeshevergen said: it says all module not configured And this is exactly the problem: You do have two module areas, one holding 26 module, the other one holding 233 modules. You did configure 52 modules instead of 26 modules for one module area which results into the missing modules for the other module area. Within the table of MPP configurations you can find the module area allocation on the right hand side as a drop-down menu. Kind regards Frederik Quote
