Zhaoyu Posted June 26, 2023 Report Share Posted June 26, 2023 Hi, I am building up a PV system with Solaredge inverter and Solaredge Power optimizer, I checked the products datasheet the configuration should be OK, however, there is a notification:"No system check possible,Please use the Solaredge site designer for checking", which causes I can not selected 'OK' and go ahead. How can I fix the problem or skip the ’system check‘? Quote Link to comment Share on other sites More sharing options...
developer_fw Posted June 28, 2023 Report Share Posted June 28, 2023 Hello Zhaoyu On 6/26/2023 at 12:00 PM, Zhaoyu said: How can I fix the problem or skip the ’system check‘? You do have 600 modules at your module area of which you did configure 200 only. Kind regards Frederik Quote Link to comment Share on other sites More sharing options...
