Aleksandar Posted May 19, 2023 Report Share Posted May 19, 2023 Hi, I have one project where client want to fill all avalibe roof space with PV panel. Included North side. With the calculation through the software for that north side, I get a somewhat excessive calculation for the production of the panels that are located in the north. Is that correct or? Prjocet file in attachment. Through some of my manual calculations, I get that thanks to those panels located in the north, the total annual production from complete PV generator should be around 9000kWh per year. And the software gives about 12000kWh. Can you check this calculation. Eschborn.pvprj Quote Link to comment Share on other sites More sharing options...
developer_fw Posted May 23, 2023 Report Share Posted May 23, 2023 Hi Aleksandar On 5/19/2023 at 8:57 AM, Aleksandar said: With the calculation through the software for that north side, I get a somewhat excessive calculation for the production of the panels that are located in the north. Is that correct or? Hm, I don't know exactly what to answer. At which part do you think the calculation seems excessive? Excessive in comparison to your calculations which is the 9000 kWh? Could you elaborate your calculations? Did you try several configurations of the module areas? At the moment your configuration integrates the northern oriented modules into the mixed string. Did you also try to contact our hotline support? Kind regards Frederik Quote Link to comment Share on other sites More sharing options...
