Brunomonti Posted May 18, 2023 Report Posted May 18, 2023 Dear, I have a problem with system configuration limits. I want to simulate ground mounted system and while I want to configure it my max system voltage module is 1000 V but inverter that I used have max. input voltage 1500 V and if I want to put 24 module (Uoc=50,15 V) in string, there is error occured. Â Best regards! Â Â Quote
developer_mh Posted June 5, 2023 Report Posted June 5, 2023 Hi Brunomonti, sorry for the late answer, your question got stuck in the approval queue.. The maximum voltage is the lowest value of the following three values: Maximum system voltage of the modules Maximum input voltage of the inverters Maximum system voltage set in the options (if it was set)  The open circuit voltage of the modules is calculated at -10°C if not specified otherwise.  Hope that helps, kind regards, Martin Quote
