Birgit Posted May 5, 2023 Report Posted May 5, 2023 Hi! We are writing a thesis using PV*SOL and need help ASAP We have designed a grid connected PV system (7 roof tops) with a li-ion battery for energy storage. For our first simulation we used 4 battery packs of XOLTA 79kWh/30KW. For the next simulation we reduced the buildings energy consumption drastically due to installation of heat pumps, the solar radiation is the same and we still used 4 battery packs but this time we get a negative battery loss. What does a negative battery loss mean? Quote
developer_fw Posted May 8, 2023 Report Posted May 8, 2023 Hello Birgit thank you for your request. On 5/5/2023 at 6:38 AM, Birgit said: but this time we get a negative battery loss Hm, it really is hard to tell without the project file. Could you send it to me via private message here in the forum so we can have a look into it? Thank you in advance and kind regards Frederik Quote
Birgit Posted May 9, 2023 Author Report Posted May 9, 2023 Hi Frederik, thanks for reaching out! I sent you the project via private message. If I was supposed to post it here instead lmk. Quote
developer_fw Posted May 9, 2023 Report Posted May 9, 2023 Hej Birgit thank you for sending the project files. I did have a look into it, but the first guess regarding the settings of the loading strategy has not been the reason. I'll keep you posted. Kind regards Frederik Quote
