Recommended AC cable section does not seem right
Hi,
My system consists of 83 KWP panels and 80KW inverter, the distance from meter to inverter is 12 meters. The software selects for the CU cable with 16mm2 cross section. based on my own calculations and my knowledge I think the proper cable size is at least 35 mm2 Cu cable or higher.
Could you please check if I'm missing something?
Hej Levan
Pardon my belated answer. Could you send me your project file via private message here in the forum so I can have a look into the configurations and double checking? It would also be nice to know your own calculations so we could compare. Did you contact our hotline support?
Thank you in advance and kind regards
