April 25, 20233 yr comment_13235 I have a battery with the .Bat of it. Is it possible for you to add it please on PVSOL ? Report
April 25, 20233 yr comment_13236 Hello sodik thank you for your feature request. I put it next to the wish being able to add inverters via .OND files. So far it is only possible to add the battery data from the .bat file manually in the same way as you would do it with a technical PDF datasheet. Kind regards Frederik Report
April 25, 20233 yr comment_13238 2 horas atrás, developer_fw disse: Olá sodik obrigado por sua solicitação de recurso. Coloquei ao lado do desejo de poder adicionar inversores via arquivos .OND. Até agora só é possível adicionar os dados da bateria do arquivo .bat manualmente da mesma forma que faria com uma ficha técnica em PDF. Atenciosamente Frederik Olá, Frederik Estou tendo o mesmo problema: que a ficha técnica deste produto (LUNA 2000 200 KWH 2h1) é muito diferente das características que estão presentes na base de dados do PV*Sol, não sei o que colocar..... Atenciosamente, Fernando Report
April 26, 20233 yr comment_13243 Hello Fernando Fernandes Quote Hello Frederik I am having the same problem: that the datasheet for this product (LUNA 2000 200 KWH 2h1) is very different from the characteristics that are present in the PV*Sol database, I don't know what to put..... Sincerely Fernando My guess is that the besaid systems are not present in our database yet. I forwarded your request to our database team. Do you mean the following systems? https://support.huawei.com/enterprise/en/doc/EDOC1100186676/661b0e12/luna2000-battery-system-specifications What exactly are the parameters that are unclear? Kind regards Frederik Report
April 26, 20233 yr Author comment_13254 it's rather this https://www.ske-solar.com/fr/produkt/huawei-luna2000-2mwh-1h0/ Report
May 2, 20233 yr comment_13299 Hi sodik this battery simply is not available in our online database yet. I forwarded your request to our database team. Meanwhile you could input the given specifications in your own created product to be able to simulate rather than waiting for the databases getting an update. Kind regards Frederik Report
