hom Posted April 21, 2023 Report Posted April 21, 2023 How much will I gain in production from the rear side? Panel: Microquanta 650W bifacial panels number of panels: 428 facing straight south White surface on the roof Installation method : Suno Solcellesystemer for bolig og næring - Solceller Global radiation - horizontal 787,61 kWh/m² Deviation from standard spectrum -7,88 kWh/m² -1,00 % Ground Reflection (Albedo) 70,51 kWh/m² 9,04 % Orientation and inclination of the module surface 111,34 kWh/m² 13,10 % Module-independent shading -4,11 kWh/m² -0,43 % Reflection on the Module Interface -46,50 kWh/m² -4,86 % Irradiance on the rear side of the module 77,57 kWh/m² 8,52 % Global Radiation at the Module 988,53 kWh/m² 988,53 kWh/m² x 770,375 m² = 761 541,59 kWh Global PV Radiation 761 541,59 kWh Bifaciality (80 % of back irradiance) -11 949,10 kWh -1,57 % Soiling 0,00 kWh 0,00 % STC Conversion (Rated Efficiency of Module 20,96 %) -592 480,80 kWh -79,04 % Rated PV Energy 157 111,69 kWh Module-specific Partial Shading -6 186,98 kWh -3,94 % Low-light performance -3 917,31 kWh -2,60 % Deviation from the nominal module temperature -163,21 kWh -0,11 % Diodes -16,82 kWh -0,01 % Mismatch (Manufacturer Information) 0,00 kWh 0,00 % Mismatch (Configuration/Shading) -144,26 kWh -0,10 % PV Energy (DC) without inverter down-regulation 146 683,11 kWh Failing to reach the DC start output 0,00 kWh 0,00 % Down-regulation on account of the MPP Voltage Range -13,76 kWh -0,01 % Down-regulation on account of the max. DC Current 0,00 kWh 0,00 % Down-regulation on account of the max. DC Power 0,00 kWh 0,00 % Down-regulation on account of the max. AC Power/cos phi -21,07 kWh -0,01 % MPP Matching -794,35 kWh -0,54 % PV energy (DC) 145 853,93 kWh Energy at the Inverter Input 145 853,93 kWh Input voltage deviates from rated voltage -27,95 kWh -0,02 % DC/AC Conversion -5 782,85 kWh -3,97 % Standby Consumption (Inverter) -81,73 kWh -0,06 % Total Cable Losses -4 201,29 kWh -3,00 % PV energy (AC) minus standby use 135 760,10 kWh PV Generator Energy (AC grid) 135 841,84 kWh Microquanta - MQ-210M-12BB - v2 (1).pdf Quote
developer_fw Posted April 26, 2023 Report Posted April 26, 2023 Hello hom thank you for your request. You did kind of answer this question yourself by posting the simulation results: The marked column is summed up to the 988.53 kWh per square meter Global Radiation at the Module. The irradiance on the rear side of the module increases the radiation, reflection decreases it. So there is an 8.5% higher irradiation which can be converted. Does this answer your question? Kind regards Frederik Quote
