Configuration of Huawei SUN2000-215KTL-H3
Hi PVSol Team,
I´m trying to plan with the Huawei SUN2000-215KTL-H3 for a 1MW park. In the database the inverter has 3 MPPTs with a maximum power of only 45,45 kW.
The max. voltage and current per MPPT are correct (1500V and 100A), just the max. power per MPPT seems incorrect.
Is this a mistake or am I missing something? Currently I can not configure the inverter in any sensible configuration.
Thanks in advance!
Boris
Hi Boris,
yes, this must be a mistake. I will forward this to my colleague from the database team so that he can contact Huawei on that issue.
Thank you for reporting this! For now you can create a copy of the dataset and edit the max power per MPPT, so that you can go on with your configuration.
