Hi
How does PV*Sol simulate Shingled modules?
When I see the modules data base in PV*Sol, I can not see that there is any possibility to make it a Shingled panel and I some panels that are written as a standard mono with 2 diodes, but this must give a wrong output especially if there is shading on the system.
If it is not possible to simulate Shingled at the moment, is there a way get a more accurate result for shingled modules?
Best regards
Jackie
Hi Jackie,
we do not have a built in simulation method for shingled modules yet, I am afraid. But we do have it on our list. If you want to try a work around, I'd assume that as a first guess it might work when you enter the cell and bypass diode count according to the datasheet and then set the string orientation so that it is parallel to the long side.
