stevewong Posted March 29, 2023 Report Posted March 29, 2023 if i want to configure a hybrid inverter for example asw5000H-S2 (but this is in the battery system not inverter) how can i configure it ? thanks! Hiu Quote
developer_mh Posted March 29, 2023 Report Posted March 29, 2023 Hi Hiu, you are right, the Solplant/Aiswei ASW5000H-S2 is not yet entered as inverter. I will forward this to our database team. In the meantime you could create a copy of the ASW5000S-G2 and edit the current, voltage and power values according to the datasheet of the ASW5000H-S2. https://help.valentin-software.com/pvsol/en/databases/components/inverters/ Hope that helps, kind regards, Martin Quote
stevewong Posted March 29, 2023 Author Report Posted March 29, 2023 Hi Martin thanks for quick reply so if in this case , i need to choose ASW5000H-S2 in inverter , and ASW5000H-S2 in battery system also ? thanks! Hiu Quote
