Boo Posted July 20, 2018 Report Posted July 20, 2018 Dear PV*SOL community, I would like to know is it possible to export the the database to pdf format for selected inverter in PV*SOL Premium ? Thank you for the reply in advance. Boo Quote
developer_mm Posted July 20, 2018 Report Posted July 20, 2018 Hello Boo, Unfortunately, it is not possible to export a dataset from the database. But it's a good idea for a new feature for upcoming PV*SOL versions. If you only want a simple data sheet of the selected inverters of your current project, you can get it via the presentation (last page). To do this, select the appropriate option for the presentation. Finally you can find the data sheet in the presentation. I hope this helps, Marcel  Quote
Boo Posted July 20, 2018 Author Report Posted July 20, 2018 Dear Marcel, Â It helps a lot ! Thank you for the quick reply. Best Regards, Boo Quote
Boo Posted July 20, 2018 Author Report Posted July 20, 2018 Dear Marcel, I have one more question. I can managed to export the inverter dataset as .wrn file using PV*SOL Expert. Is there any way to open this file ? Best Regards, Boo Quote
developer_mm Posted July 20, 2018 Report Posted July 20, 2018 Hi Boo, no you cannot open the file resp. it is not intended to be opened by third parties. I don't know what you want to do, but if you want to share your own database entries, simply save them in the pvsol / project file. When someone else opens this file, your database entries are imported into their database. Kind regards, Marcel Quote
